Warning Light
02ViperMtn
Kamloops, BC
I've been out twice this season now. I have cleaned the carbs and the pwer valves. I am getting the warning light and engine light flashing 7 times. It does not do it continuosly just some times. What is this, any suggestions?
I am also finding when I first hammer the throttle hard I don't get an immediate crisp reaction, sometimes it will bog slightly. Any thoughts on this? Are they related?
Well I believe that is the code for YPVS. So your power valves have some sort of issue. The manual says "Short circuit/locked"... take that as you wish.
Hope that gives you a direction to go
i know that i have the cables tighter then they were before. They are at 2.5mm but maybe i should loosen them up some. Would this cause the warning light?
Use tester,, engine needs load plus throttle position.. Would not recommend running bare clutch above engagement speed....... don't want to make contact with faces of clutch..
i didn't ride and test it yet, but fooled around with it on the trailer for a minute. When i idle it down it moves. At what point should it move at the high end of rpms?
Yea, it starts to work above 5-6,000g on through wot... will also wiggle coming back down to idle..
problem seems to be solved with the warning light. I loosened the power valves a hair each the warning light (7 blinks indicating YPVS problem) is no longer happening. I know i had them tighter than they were previously.
As far as your bog off the line, have you cleaned your carbs this season? Sounds like lean on the pilot circuit.
i cleaned the carbs and pv's. I know the carbs should be spotless, they were near spotless when i took them apart. Lean on the pilots eh? It just doesn't have the snap of the line or from 0-5500 RPM, but once past that, hang on.
Check your drive belt. A worn drive belt will make it sluggish out of the hole. Also if you do change the bely spend the extra 20 bucks and but a genuine Yamaha belt. It sounds weird but it definately makes a difference. Its beem reviewed many times throughout this site.
