jgustman
I've been searching threads for the correct answer to my question and haven't found the right answer, hope this will clear it up for many others.
I have a 2004 viper s and have the over rev problem, seems to be the same across the board bottom to top it stays at 8750 rpm, sometimes higher. Will just adding the 4.5 gram rivet with stock 47 degree helix pull the revs down far enough?
OR
Will the stock yamaha RX-1 51/43 helix and green or red secondary spring will get me close or will I need to put in the 4.5 gram rivet as well? I thought I saw a post that this RX-1 helix really acts like a 48/40 dalton and will over rev as well without adding even more weight than what the stock weight will allow. I see turks recommendation says 53/43 (dalton) or 48/40 advant-edge helix. I've found a 54/44 micro belmont which would work as well, if the 51/43 rx-1 helix doesn't....
So in summary: RX-1/Apex helix (51/43) good enough, or forget it and find a 53/43 dalton or other brands?
OR
