YPVS Question
SRXBOY99
Red Deer, AB
Ok, i'm going to risk sounding like a complete moron, but what are you talking about when you say "cable pull through?" In past posts, it seems guys have mentioned that when the cable gets REALLY out of adjustment, they can "pull through." Does that mean the cable wears on the power valve if not adjusted properly?
Thanks...
It means the cable has pull'en out from the end of the valve,there's a groove in the end of the valve that the cable attaches too.
Happens with in proper adjustment and dirty/gummed up,not being cleaned regularly.
try a search on power valves you'll be reading till morning.
here look at this ..you can see the pullrd thru valve ....and you can see a set that i have repaired by installing a stainless steel inceret ....let me know if you need yours repaired ......
As I have learned, there really is no stupid questions.If you dont ask you will never know!If you do have pull through's its worth your time to get them repaired for the sake of 20$ each compared to 120$ per valve JMO
This may be another dumb question but is there any way to tell you have a power valve not working properly buy riding the sled ? I took mine out and cleaned them but I never took the valves off the cables. My sled runs great and has tons of power, but do you know when the pull through happens?
ONLY true way to know is pull them appart,open the housing and look. A srx has great power if there not working so it's hard to tell by the butt dyno.
repaired valve is exactly the same as a new yamaha but better cable slides in slot cut in head ....pull your out send me a pic and mail me your valves and ill hook you up better than new
