sagerider
Quick overview: I've got three mountain maxes, 2 700's and 1 600. I've decided its time to learn how to work on them. My son's 600 is new to us, 2900 miles (no other info on history) have only run it enough to load it, and unload it into the shop. It is terribly dirty (was stored outside under a plastic tarp, when it didn't blow off) but seemed to run good and was only $900. So before we run it, I'm trying to go through the whole thing cleaning, inspecting, repairing/replacing as I go. This is my first time going beyond basic maint. I do have a Clymer shop manual I'm using to baby step me through it.
Question #1: Airbox, carbs, exhaust, head, and cylinders are out as specified. How do I get the piston pin clips out. It reads simply "Remove the piston pin clip from the outside of the piston with needlenose pliers. Hold a thumb over one edge of the clip when removing it to prevent it from springing out." Well, I grabbed hold of it with needlenose but can't seem to budge it. I might be being too gentle, but I'm trying to be careful?? Also, do both need to be removed to remove the pin? The book isn't specific.
Question #2: The cylinders don't have any obvious scoring or staining. I've seen chewed up cylinders before... these aren't chewed up. I can still see the crosshatching. However, all three pistons have some "light" scaring. Book says I can w/400 grit or fine oilstone. Also, all three pistons have light to dark tan and a some black staining around (but mostly above) the piston pins. Is this normal...are they good or bad? If good, how to clean/repair them? I plan on installing new rings.
I could provide pictures if anyone is interested. So far, things look better than expected, I think. Gaskets all appeared intact.
Thanks for your help.
