timl1978
So I rebuilt the top end, adjusted powervalves, and changed my drive spring this fall. First time I was tooling around in yard I heard this weird noise every now and then. It seems to be under throttle only. It sounds like a metal on metal sound like when you'd tap the clutch with a small hammer. Could something in the clutch be making this popping sound? Could it be the powervalves popping against the cylinder if they are adjusted too tight? I heard a trick that you can look at the powervalve servo and if when you idle down it bounces up and down they are too tight...it isn't bouncing. Should I pull the clutch apart? It doesn't sound like an internal issue or a knock. Maybe it's internal and I'm f'd.
