panteramatt said:
No noises at all just kinda stalled out and now I cant pull it. Why would it stall, then start up then stall again? What would cause the piston to sieze? Think maybe I didnt get oil to a cylinder?
To answer your question, momentary seizure then full seizure after restart.
Well there is a couple of things that may lead to lack of oil - if this really happened.
First would be how much oil is in the resivour, if full okay onto the next question,
Was the oil that was in there mixed with a non compatible oil and it gelled? -need to check to find out.
Did someone mess with the throttle cables? Because, there is one cable that runs the oil pump and the other runs the throttle slides, the one cable runs the variable ratio oil pump so that you get enough oil at high RPMs(not like premix systems), if the cable is way out of adjustment or not hooked up then this is the cause of your failure.
There should be an in-line filter to your oil pump between the oil bottle and the pump, "if" the filter is plugged then this will cause a oil related problem. also if the injection system was apart and there was an air lock or bubble in the system again here is your failure.
You REALLY need to pull the heads and cylinders off of that motor to see what is going on or happened. Because this will also tell a story of where to look for the issues at hand.
