2" Track on srx
kirk700 srx
labrador city n.l
I just tore off my 1.75 track off my srx , I already have 8 tooth drivers . I was told by the yamaha mechanic that to put a 2" on my 121 noaction skid I would have to lower the mounting holes for the suspension. He said he put a 2" on a sxr 700 and had to lower the mounting holes. Has any one else had to change mounting holes to add a 2"? I believe the middle bolt holes were the ones he had to change mounting position on, but not sure.It seemed like there was enough room with the 1.75 but I want to be sure before I buy another track!
I forgot to mention I have the viper suspension in my srx. If I went with smaller upper idler wheels instead of 7" If I went with 6" Or6.5 will I run outta track tension adjustment?
Didn't have to change anything? How did it clear with the 9 tooth drivers?
lakeofthewoodsrider said:
I have a 2" on my SRX, and did not have to change anything, man do I like the way it hooks up on the trails and lakes.
kirk700 srx said:
Thats wht ia runnin 8 tooth drivers and soon to be 2 " ordered it today ...camoplast challenger!
You will love that track. Put that on the 500 VMax and man, does it play well in the fluff!!!!
Yup, get a big track like that on an SRX and hold on! I left stock 98 gearing in my srx with 8 tooth anti ratchets with an 1.875" track, AMAZING!!!
I dont have stock gearing, mine is 22/40 and clutching is 8dn20's and 54/44 bender helix , so it should be WILD!!! It was great with the 1.75 until I put the rail through the track !
Thats good Cause this year is gonna be a bad one for slush or "slob" we call it here in Labrador! Usually this time of year is -40C or colder and this year it is 0C today gettin lots of snow but the ice is sinkin!
What 2 inch track are U running in the SRX, I would like try the 2" track for drag racing instead of 1.25 as the SRX are known for trenching in drags
I ordered the Camoplast challenger 2.0! I had the back country1.75 on and it was great hooked up wicked! I can only imaging what the 2 is gonna do!
Can U post a picture of the clearance from the 2" track to the heatXchanger
Thanks Andy
