Roscoe
I'm thinking about going to look at a 2003 Viper with approx. 2400 miles, no studs and I'm told its showroom condition. What are the pros and cons to this sled. Is there anything I should look for other than the obvious? Whats the price range for this sled? Thanks
Look to see if the owner has installed a rear HX.
Roscoe
Netefrog said:Look to see if the owner has installed a rear HX.
a what?
Rear heat exchanger.....
viperules700
Needs updated suspension!
The vipers biggest flaw is the rear suspension. In order to get these sleds to ride good, you need to look else where for a used or aftermarket suspension. The stock suspension is hard to adjust/tune. I would plan to spend some money there if you intend to ride it yourself. I would also pull off the servo cover and check out the exhaust valve cables. If you don't take alook you could be into hundreds of dollars of parts to repair/replace the valves.
