Hot starting
Bomberfan
kenora
Anyone else have to hold the throttle to start when hot on an SRX700? Will start good when throttle used??
many yammy tripplee need just a touch of throttle when they are warm. Both my viper and srx are the same 1 pull warm just with a touch of gas
Yep nature of the beast.
Mine will hot start most of the time without throttle. But if I want to make 100% sure it doesn't need a second pull then a little throttle it is. Usually do it when there's people around. ;)
X2 - I would only add that I never had to touch the throttle when warm when my pilots were at 1-1/2 turns. I turned them out to 1-3/4 reduce occational idle hang but will sometimes have to crack the throttle slightly after a 10 minute or shorter soak. I have them at 1-5/8 but haven't riden it enough this year to conclude anything.
They all do it... Sometimes mine will start with no throttle, sometimes it will take a shot of almost half-throttle to get 'er going. Usually I just give it a quick shot as I'm pulling of about 1/4 throttle, seems to do the trick 9 times outta 10.
