So, my dilemma continues. No power, boggy on throttle, and then when it reaches a certain rpm it takes off like a bat out of hell. Can't just putt along or it pukes on itself. Carburetors are SPOTLESS. I have just a couple of questions.
1) What exactly is the pilot screw on the carburetor adjusting? I mean I know its for the pilot circuit but is it adjusting fuel or air?
2) I have tried 2 1/2 turns out and 1 3/4 turns out from lightly seated. 1 3/4 out and it was doggy and sounded like it was skipping and wouldn't rev up. 2 1/2 turns out and it runs alright but if you try to rack on the throttle it backfires. If you choke it, it revs up like it should but wont idle and eventually pukes out and dies.
3) What should that screw be set at? I have not been able to get a definitive answer as to what the stock setting on this is? Should I try 1 turn or 1 1/4 out?
HELP!!
Thanks in advance!
HELP!!
Thanks in advance!
