BLUEBALLER
Try loosening the bolt for the FRA, and setting it in the medium or hard position. It just might be enough for the rear bolts to line up.
Also turn your ts3 so they are flush on top, or at full transfer, It will give you more room. Maxdlx
BLUEBALLER
after looking at your first picture again, I would say that your FRA bracket is in backwards. I believe the teeth go to the front of the sled. Looks like yours are in backwards.
pbspecial
- Oct 24, 2003
After all that, yes, it was in backwards! Once I flipped it around, it lined right up no problem. Oh well, at leas I know what I'm doing now. Thanks for all the help.
PB
PB
Good catch BlueBaller
, I new it had to go in easier than that...
YaMon
Would you suggest locktite? Red or Blue?
blue only. red too hard to break loose later.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
agreed, red is very hard to break when you take it off again. Inless you have air tools, I would not suggest it, go with the blue, it will be more then enough
And I will make the blue as well...its unanimous
I have never loosen my rods, just used a rachet strap to compress the spring and align my bolts. Rear lifted and use a floor jack....Might have to try the easy way next time. Brent
pogoyammie
yeah familyman...do it the easy way...lines right up (as long as nothing's in backwards...and yes pbspecial, we all have put plenty of stuff in backwards, admit it or not)
