Ya, you need a good break in of at least 25 miles. Use varying speeds along with variable throttle position,, After at least 20 miles you can give it gradual WOT for brief durations. U do not want to jab the throttle,, but want the belt to ride to the upper part on primary and be sucked down in the secondary... You don't want to run it at a steady speed or rpm during break in....
