started my new project today starts up fine idles good just when you go to rev it up it bogs bad and will not rev. i even tried another rack of carbs same thing. where should i try first. or what do you think it could it be a bad ground is.http://www.youtube.com/watch?v=OmKtMj9eKBY
is it a stock engine ?
kirk700 srx
That link says it is a private video
Throttle cable to tight? TORS activating?
kirk700 srx said:That link says it is a private video
X2.......I'd check out your vid if I could.
ther is slop in the cable and the tors is bypassed also tried it with tors no differant stock motor 42.5 pilots 1 1/8 air screws 150 147.5 147.5 jets i tried two differant carbs and the same problem. chock is set right. just need to step back and take a break from this machine. could it be weak spark? i am going to try a another set of coils tommorow and also a cdi.Whammy said:Throttle cable to tight? TORS activating?
Try video now
kirk700 srx
Did you check the reeds? Did you check the stator for current? Pickup Coil? is the exhaust plugged with something? It almost sounds like the srx's does when the exhaust hole is plugged with snow.
YAMMIEGOD3:16
PETE, YOU HAVE STATOR ISSUES. 3:16 (yammie tony)
kirk700 srx
Thats what I was thinkin also But it usually seems like I am always pointing out stator issues lol makes me think I am a stator freak lol
YAMMIEGOD3:16 said:PETE, YOU HAVE STATOR ISSUES. 3:16 (yammie tony)
YAMMIEGOD3:16
YEA ME TOO loL. BUT I HAVE SEEN ALOT OF BIG RACE SLEDS WITH THAT PROBLEM, GUYS GO RIGHT AFTER STATOR FIRST. TELL YA ITS EITHER THAT OR CARB ISSUE, WHAT ELSE ? 3:16 (yammie tony)
staggs65
if the stator checks out try 1 7/8 or 2 turns out on the fuel screw
i already tried the fuel screws i was around two turns then back to 1 1/8 turns i will try the stator today.staggs65 said:if the stator checks out try 1 7/8 or 2 turns out on the fuel screw
well it was the stator it runs awesome the fastest srx without studs i have ridden carries the skis across the field. i am so happpyYAMMIEGOD3:16 said:PETE, YOU HAVE STATOR ISSUES. 3:16 (yammie tony)
kirk700 srx
Post a new video now so we Believe you LOL
YAMMIEGOD3:16
COOL!!! 3:16 (yammie tony)
All this is interesting as Yamaha's are known for their reliabilty and CDI + Stator issues are something we Yamaha owners/riders have never had to worry about.
We are all, [Vipers + SRXs owners], entering into an era where our sleds are aging to the point that even our Yamahas are having stator issues. Of course our sleds had to get around 10 years old before this started showing up!!
Most Cats + some Ski Doos usually have come up with stator issues in less then 3 years of age!
I had performance issues on my 2002 SRX that a new stator helped cure as well...I guess we shouldn't be too critical since our sleds are reaching an age that most owners of other sleds can't even dream of !!!
JM.02c
JM.02c
here is the proof it works.http://www.youtube.com/watch?v=C8cJUKk2mywv=Pwb7jBR4LfU
another vid.http://www.youtube.com/watch?v=Pwb7jBR4LfU
