re count the teeth on the gears and the number of links on the chain to verify is correct,otherwise as others have stated..it does work.Guess I will find out by Friday when my chain gets here.....saying a prayer!!!!!
mustangzrule
Too bad there is no real sure fire way to do a 1000' drag with the 70 then again with the 68 and see if there really is a difference in friction and how much. Too many variables like the ice changing with every pass, driver inconsistencies.
Anyone ever hear of a dyno for sleds? maybe a new product market.
yea, that was a no brainer. probably does work for the 23/38, wasnt happening for the 19/42, period. i have changed and set up more gears ratios than you can count, from enticers to apexs. not saying yours wont go, just saying mine didnt. or my low mileage chains are within spec.bluemonster1 said:re count the teeth on the gears and the number of links on the chain to verify is correct,otherwise as others have stated..it does work.Guess I will find out by Friday when my chain gets here.....saying a prayer!!!!!
