JERSEYJOE
My 2003 Viper is flashing the diagnostic light. It is flashing 7 times? What does this mean?
Cam/ Viper adict
Flashes on off 7 times and repeats? May have to do with your Power Valves or servo..
JERSEYJOE
viper
do I ned to adjust the power valves?
servo problem.....
remove servo cover,idle sled down to 900 rpms,does servo activate and open PV's smoothly??
Cam/ Viper adict
Does your viper have electric start? Have the power valves been cleaned and is the servo operating correctly?
JERSEYJOE
power valves
Just cleaned them at the beginning of the season. Never adjusted them , ever.
I guess I should search the forum on how to do this.
first....JERSEYJOE said:Just cleaned them at the beginning of the season. Never adjusted them , ever.I guess I should search the forum on how to do this.
to rule out a servo problemdaman said:remove servo cover,idle sled down to 900 rpms,does servo activate and open PV's smoothly??
YAMMIEGOD3:16
JOE, PM YA. 3:16 (yammie tony)
02ViperMtn
after i cleanded my pv's i had that light flash 7 times and had never had it before. I know when i set them this time they were set to spec but was not that same as before. I loosened the pv's to about 3mm and the problem is gone for good.
Follow the PV valve setting instructions in the Tech section, I bet it goes away.
