14 inch wide track on an srx
needaSRX
Manitoba
can you put a 14 inch wide track on a stock suspension in a SRX such as a snocross 1.5x14x121 2.52 pitch :letitsnow :2strokes:
No problem fitting that track in your SRX as long as you're not running studs. The stock 9 tooth drivers will work fine.
You will need to remove the front heat exchanger protectors and tunnel protectors for clearance.
I have a 1.25 in now with tunnel protectors out I was more looking for the 14 inch wide deal as will I have to modify my undercarrige somehow or leave it as is
that's why I want to know if it will work in a SRX
I was told to get a 1.5 snocross track for snow draging and I was looking at some snocross track and they were all 14 inches wide
ottawaair said:
Why do you want a 14" wide track??
looking to lose a few extra pounds of rotating mass ....best place to lose weight takes more power to move rotating weight ....
the one I was recommened weighs in at 33lbs fully clipped but was told I have run extroverts for drivers
We put a 14 x 121 x 1 on a ZR 900 and it did gain a couple mph but deff lost traction. He wasnt set up right but its hard to deny the speeds of a Firecat being related to the narrow track....
I would be curious how much top speed is gained vs loss of cornering (ski lift) and loss of traction on an SRX...
staggs65 said:
so the track windows and clips are the same c-c measurement as a 15. seems to me that would answer needasrx's major concern
Oh yes deff. The Phazer 14" wide is a direct bolt on. No changes required. Same pitch and clip spacing...
yes thats what I wanted to know if these are the same measurements where the slide rails ride from a 15 wide to a 14 wide
You're going to lose some traction & deep snow capability, srx's already trench terribly, but if you're looking for top end the gains may outweigh the losses.
The track I'm looking at is 1 1/2 snocross track not looking for topend just better traction for snow drags I'm still trying to gain a sled length on an local F7
