yegs
- Nov 16, 2004
Does anyone know if a 1.5" paddle fit under a 2002 SRX without switching drivers? If not, anyone know how high of a lug will fit without changing drivers?
A lot of guys run 1.25 inch tracks without having to change drivers. I'm not sure if you can get a 1.5 under there or not...if you can, you would have to take out the heat exchanger protectors for sure.
B2SO
- Aug 18, 2003
yes
you cant run studs and you might need to notch the track alittle ...
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
I havent heard of a person trying to do this but you will definitally not be able to run studs and it might not fit even with out the protectors out. I am almost sure of it. You will most likely have to change your drivers or notch the track.
nope, above post are incorrect, a 1.5" fits with just the protectors(stud and tunnel removed), the biggest you can go is 1.75", thats whats one my 136" srx and it has 9 tooth stock drivers, it really hooks up awesome!!
GETZY
I had an 1.5 track on my 2000 SRX, my buddy had a 1.25 and he seemed to have a little more topend.
1999 SRX I am running 1.5" right now. I can fit my fingers between the lug an heat exchanger no problem. I removed the tunnel and heat exchange protector.
