timd222002
Looking for advice on clutching for 660. I see alot of people on here with recomendations for clutching but there recomended rpms are alot lower than that of haucks pipes. Hauck recomends 8900 too 9200 rpms for there tripple pipes. Any suggestions?
timd222002
full tilt viper
clutching
Heel clickers or heavy hitters. Heel and mid only, no tip weight! Straight 47 on the HH. 48\40 for the clickers.
timd222002
I don't know what the angle is on the helix its a hauck aftermarket one
journeyman
timd222002 said:I don't know what the angle is on the helix its a hauck aftermarket one
Good luck getting them to tell you too.
timd222002
Primary has 8EK-00 with Green white Green
timd222002
Also has 2 rivets on each
mopar1rules
what's the letter stamping on the hauck helix?
timd222002
mopar1rules said:what's the letter stamping on the hauck helix?
It has a a 0 9
timd222002
The secondary spring I don't see any colors on it just Black
mopar1rules
timd222002 said:It has a a 0 9
you'll have 4 #'s stamped on it......0, 3, 6, 9.....that's for hole identification. there should be a letter stamping on it somewhere. is there maybe a "V"?
also, on the secondary spring, the yamaha springs are black, but will have a paint color dot on one of the springs coils. stock on your sled is red, but most people switch to green when changing up the clutch setup. so, what color dot does your spring have?
timd222002
mopar1rules said:you'll have 4 #'s stamped on it......0, 3, 6, 9.....that's for hole identification. there should be a letter stamping on it somewhere. is there maybe a "V"?
It's an X?
