jon123 said:
I bought a used metric M-10 a couple of years ago with the intention of installing it. I had a real hard time finding parts for it. Fast discontinued most parts for it so be aware that parts may not be available in the future. I chose not to install the one I had because I could not even find bogey wheels or slider blocks for it.
Fast makes a bogey wheel conversion kitt that changes the wheel to standard ones, for about 200 bucks replaces all of them with new bearings and shafts... you can go online and order the sliders, or if your handy make them yourself out of teflon. all the m10 parts are prety easy to make, its just aluminum pipeing made from probley a 70series grade for hardness and wear... If you have ascess to a lathe, your laughing, its all so easy to rebuild yourself than. If buying most of these parts from fast its going to cost you big money. I just installed my metric m10 into my viper tonight. a few tips:
Get the fast template laminated with 10mm laminate. (its easier to Hold in position.)
Check the front shaft and its aluminum keepers that go between the tourque tube and the 2 aluminum mounting post. ( I had a total of 1/8" of play in between. This is with the new mounting kit that fast sends you for the yamaha sleds.) NOT GOOD, BUT NOT A HUGE DEAL I made new pieces to keep everything snug.
I just found the slides for the m10 from kimpex for 14.99 each. (I dont have the part number now but can get it. dont be fooled by looking them up and ordering the ones that say m10...They are for the standard m10 and dont fit)
bearings are easy to remove and match up from the idler wheels.
You can rebuild a m10 for cheaper than buying replacement parts. Its time consuming but worth it.
Being a welder I had to reweld some of the holes on my aluminum rails that were worn slopy and blend grind and redrill them. (be carefull rails dont warp....GTAW perfered, and weld a little at a time and flip to other side to controll heat displacement) if they do warp thay can be straightend in a press.
had to reweld the rear tourque tube that tends to wear on the bottom shaft if the inside sliders are worn. (insert a round piece of brass and build the worn steel back up. and grind it smooth with blending disc (aluminum disc) on a grinder and use a pencil grinder on inside.
Use DISC-LOCK Washers where possible
http://www.disc-lock.com/stainless-steel-washer
I had tourque tubes sandblasted and powder coated and rails polished.
p.s. Make friends with a machinist, and sorry for ranting.
I will take pictures tomorow and post for you guys to see.
