54/44---silver spring results
mopar1rules said:
belt doesn't ride to the exact top of primary. it will always stop about where you're seeing it, unless you machine primary for overdrive. also, the reason your engagement is soo low now w/the y/s/y, is cause of 35kg preload, instead of 45kg like w/stock y/w/y.
Ok thanks. Im use to my Cats that once clutched right, the sheaves were wiped within about 1/16" of the top.
I thought maybe I had more to get but I was able to touch off 120 (speedo) and my belt was cool so Im happy ;)!
:2strokes: :letitsnow
unchained said:
below freezing on cold days and low humidity, this set-up rocks. Above freezing on warm days it just cant pull it.
May want to check jetting for your temps you mostly ride in.
update
using 8DN-20 weights,fully loaded with 4.5 in both holes.Then using a 54/44 helix..silver spring is to stiff.Must go with a Green spring at 60 or 70 if needed.The silver would be used more on ice or grass drags with mega number of chisel's on the track.I asked Turk and this he told me to go with..
I have a special on Moth-HP Balls guys. ;) $99.00cad gets you
a FULL BOX of fast HP at the drop of a ball. These beauties made
the Merc 340 Sno-Twister the legend they are. Save $200 on the
Bender can and I'll send you TWO, get that? TWOOO Boxes of Moth-HP.
Please send CASH to:
Moth-HP INC.
FreeHp St.
Port LYER ON.
Canada KOK HOHO
bluemonster1 said:
moth balls and clutching don't mix.... :rulez: got my own secret formula!!!
Lol.Fabulous BLUE, Fabulous!
I should be hearing from Gerry Iantomasi soon. I have to stuff that
Sc-3 into the sled when it gets back from the massage parlour ;)!
Getting an itchy trigger finger #$%&*
