billbies
just trying to verify im trying to start from stock and have the stock part # but whats the actual nozzle Q-4, Q-8 etc
any help is appreciated
Scootertrash
I am guessing you are talking about the 99 SRX 700 in your info under your username?
From the 2000 SRX700D/SD manual the factory sizes are:
Jet needle:6GM26-3
Needle Jet: Q-6
ETA: Here are all the factory specs from the 2000 manual:
Carburetor:
Type/quantity TM33/3
Manufacturer MIKUNI
I.D. mark 8DN10
Main jet (M.J) #1: 147.5 #2,3: 146.3
Pilot jet (P.J) #42.5
Jet needle (J.N) 6GM26-3
Needle jet (N.J) Q-6
Pilot air jet (P.A.J) 1.0
Pilot outlet (P.O) ø0.9
Bypass (B.P.1) 1.0
Pilot screw (P.S) 1-1/8
Throttle valve (Th.V) C.A 2.5
Valve seat size (V.S) ø1.3
Starter jet (G.S) ø1.2
Float height (F.H) 11.3 ~ 15.3 mm (0.44 ~ 0.60 in)
Fuel level (from the bore center) 36 ~ 38 mm (1.42 ~ 1.50 in)
Engine idle speed 1,800 ± 100 r/min
Jet needle:6GM26-3
Needle Jet: Q-6
Carburetor:
Manufacturer MIKUNI
I.D. mark 8DN10
Bypass (B.P.1) 1.0
billbies
Thanks for the info anyone know what the dimensions or a chart of needle sizes are
Bill
Bill
