Spinner18
Set-up
8dn-20 4.5 gram each hole
stock yellow white yellow primary spring
red seconday spring, wound to 100* holes 1 and 9, tried 80 and 90 wrap
52-46 micro belmont helix
Did a few pulls with this today, 38-39* out about a 1/4 mile on the lake
From a dead stop, it would rev 8500, back off to 8200, then climb to 8350 or so...
BUT when cruising at 40-60 mph, if i go WOT from there, its VERY boggy. After 2 seconds it would then rev out. It pulled very hard from a stop
Speeds, I ran it about 10 times, each time on GPS, 101-104. Speedo read 109-110.
tried the 53/41 helix for the heck of it also, didnt seen to accelerate hard, rpms were at 8500, but would only pull 103 on the speedo, which was 97 on gps. that helix is garbage.
Why is it boggy so bad in midrange? Do I need to change to stock weight in the middle hole? will a lighter weight there clear that up, and possibly raise top end rpm just a tad?
Sled has stock exhaust on it, stock jetting etc. I weight 235 also
