got 51/43 helix in green at 70 tonite.Will test in morning and let ya know what gives.
I now (finally) have 8DN's with 4.5 in both, Y-S-Y spring, 54/44, silver at 6/2 and from a 10 mph roll it absolutely rocks all the way till the speedo is burried and the 03 F7 is behind me! From a 50 roll it isnt exactly a dog but far from perfect. Overall Im pleased especially considering it was in the low 30's weather and my 0-60 greatly improved compared to the stock primary (8Dn's and stock spring).Turk said:You are lacking throttle response because your set up is for best acceleration & top end. If you want to be fast you sacrifice backshift. You can,t have it all in clutching. You give something up to gain somwhere else.
Wow?Spinner18 said:unchained, you are running 8dn-20's? i dont see how your pulling 4.5 in each with a softer primary spring either, unless the silver is that much stiffer in the secondary...i dont have a silver spring, but i have a pink i tried, slightly stiffer than the silver. and crisp midrange, but didn't pull as hard, and less top end than with the red spring.. iq still supposed to have 145-150 hp, apex same... both of them were showing 105-108 on the speedo and i was pulling when mine showed 111. keeping in mind temps today were 30ish.
also unchained, how the hell are you burying the speedo, i cant see it happening on a warm day... lots of track spin or what? I'm getting lots of traction, 1000 ice screws in the lugs. mine rocks from a 10 mph roll also, but from 40 it isnt exactly a dog, but like you said isnt perfect... gotta keep in mind, these triples need RPM, and around 40-50, the rpms are under 6000...
have you GPS'ed in warmer temps?
