Wyoming pics, finished viper and wrecked viper:-(
The viper was a lot of fun and worth the extra effort to get it done, did well out in the mountains, would rev and pull hard to 9100, I was kinda concerned about this but i need to call hauck and see what rpm these pipes are good to. Sled would climb unlike anything else I have owned, but that is not saying much. the power just kept coming on as I was headin up for climbs, always seemed to stay in the power band, the skid worked awesome and the transfer was sweet, but I had a bolt come loose on the lower w-arm mount on the last day, (I lock tited everything on the skid!!!) and it tore the upper w-arm mounts out of the tunnel!!! I am going to build a reinforcement plate for it and get it back together, hopefully headin out west for the weekend of apr. 17th
Mods are as follows:
Flipped shock bracket on trailing arms to raise front 2"
removed sway bar
custom cut skidplate
custom 2003 yz125 seat with monoshock
2010 arctic cat 162 rails with proaction skid parts (lots of custom stuff in here)
IPM 9" idlers with 1" offset axle
IPM 7" carrier idlers
attack 20 162" track (trimmed to fit :-(
Wahl 7 tooth drivers
custom tunnel extension
Arctic cat crossfire rear cooler
Mountain addiction gas rack
Slydog powderhound skis
RSI 8" riser
RSI handlebars, pivot adapter and pad
Powermadd handguards and mountain strap
Holtzmann attac
Hauck husher pipes
Carbontech reeds
Stock primary with GWG spring and inner al. rivets
Hauck 43 degree sec. Helix with silver spring 90 twist
19-42 gearing
custom ram air intake with functional ram air and frogskin moisture protectors on dash and ram air pods (works awesome I will do a thread on this as I took lots of pics)
Large billet gas cap
Billet pull start
petscreen over all vents
custom LED brake light
custom transfer kit
The cool thing about all of this is it wouldn't be possible without all the help I received on this site and sw. Everyone here was looking out for me and many eyes are better than 2 and i hope I can add my findings to others on this site and help the same way others have helped me!!! Thanks again TY
