xtc700jeff
Use stock springs at the manifolds not benders they break , make sure you put ALL the springs on all the other places to keep them tight
I can't speak specifically about psi's, but XTC Jeff's sled with porting and Bender pipes rips pretty much everywhere, the only downside is it likes fuel as has been mentioned.I think the only other pipes with broad power like benders is power inc.'s, but there quite a bit louder I understand.mopar1rules said:yeah, porting will wake these sleds up. seems like your interested in max power? thing is, that a pipe that makes most peak hp, sometimes isn't always the best for the trails, cause it sometimes makes like no bottom hp, so the bottom end is flat. my bro's buddies cpr piped sx-r is a pooch on the bottom IMO. totally flat. sled does nothing under 6000 rpm. if i was him, i would look into a set of pipes that gives a broader power curve. i think the psi mod blasters were good all around pipes?? can someone confirm??
