MountainMax
Hey guys, I had the engine out of my 2002 MMax due to oil leaks from one of the oil hoses, so I decided to change them all out and use tye raps to secure them instead of the factory steel sleeve clamps which are very weak now. anyhow, my delima is which way do the check valve arrows face, there are two of them, one between the oil pump and fuel pump, the other between the oil pump and the bottom of the crank case. The manual don't show any pics but says in one place to face the arrowws towards the crank case, fine i guess for the fuel pump one, but what about the other one? i don't want to guess here and loose my engine.....
