downic
I'm in the process of summerizing my new (to me) 1998 SRX700. Last step is to drain the float bowls on the carb.
With a fair degree of difficulty, I've managed to remove the air box - which has revealed a bit of a mess. I should probably remove the carb rack and give it a cleaning but I'm not really up for that challenge.
I see the nut on the bottom of the bowls - see pictures. Just wanted to confirm that it is possible to drain the bowls without removing the carb rack?
