JeepJimmy
99vmax 700 deluxe with reverse. what oil did yamaha use factory in the chain case. if i cant get ahold of some amsoil what should i use instead. thank you
75-80, same oil as a non reverse model.
FuzzButt
Do you need some amsoil chaincase oil? I know a guy...
JeepJimmy
could i use some 75w-90 syn or 75w-140. i have that.
FuzzButt
The recommended oil in my manual states..
As long as it meets those specs fill it up with 8.8 ounces or so. I'd go with the "right" product over the "it works" product. The Amsoil gear oil isn't too expensive. The Series 2000 Synthetic Chaincase Oil Product Code: TCCBE-EA is $6.95 plus shipping and tax. Cheaper than the gasket and way cheaper than a set of bearings. See https://www.amsoil.com/storefront/tcc.aspx for more info on it.
Gear Oil API GL-3 SAE #75 or #80
PZ 1
- Mar 12, 2005
JeepJimmy said:could i use some 75w-90 syn or 75w-140. i have that.
The 75-90 will work fine.
