A couple of bucks
bluemonster1 said:Nice looking paint but stunk up the house..wife wasn't to impressed...lol
Tell me about it.
sleddineinar
Yea, just did that... my wife was less than impressed with the smell.
my wife baked 2 pies in the oven the next day..there was no issue of smell then,even though the pipe was smokin at the end were there was oil residue..Smoke detecter went off once because I opened oven door to much to peek inside.Windows open and fans going.All is well at Blue's house now.LOL
spent most of my day putting 600 motor back together,didn't rush and took my time with everything.Just have to install the oil pump and lines yet and it is time to drop it in the chassis.
BUT..have to clean the chassis first and get the steering rod back on.
Winter is knocking at the door.Blizzard conditions one Province over and up to 25 cm of snow just west of us....lots of rain right now but temps are to mild yet.If it was below 0 degrees today,we would have had a couple feet of snow and drifting since the winds are crazy.A huge weather system is passing on through.Man winter starting early for a change....
Bluemonster2
Looking good Doug, too bad that snow missed us
Well got the motor dropped into the now well cleaned chassis.I can shoot them Japanese engineers.Can't believe how they made it so hard to hook up the oil line to the pump from the tank and getting the big cooling line on at the same time..
BUT the worst is the bleed screw for the pump,it is way down on the top of the pump which is way down under the engine bracket..good thinking.At least on the SRX they have an extension line with bleed screw exposed to easily....damn
Thank goodness I have the motor on a electric winch for lift or lowering,could never do it all by hand..impossible.Thursday will slowly work on bolting down motor and lining it up ,then mixing new anti-freeze,clean carbs and plug in all cables and install the exhaust...will see how far I get.CAN'T wait to hear her running also.
Thank goodness I have the motor on a electric winch for lift or lowering,could never do it all by hand..impossible.Thursday will slowly work on bolting down motor and lining it up ,then mixing new anti-freeze,clean carbs and plug in all cables and install the exhaust...will see how far I get.CAN'T wait to hear her running also.Attachments
Wow looks fresh out of the showroom!!!
Nice work!!!
Nice work!!!
Bluemonster2
Looks like you will have her running soon enough!!!
A couple of bucks
bluemonster1 said:then mixing new anti-freeze
Just a reminder as we all know........no tap water. Try to get some water from a dehumidifier.
I always use aluminum friendly anti-freeze and deionized water along with Water Wetter with my mixes.Wasn't to bad cleaning her up.Also re-routed the wire harness from under the motor to over the pull start .Since the motor was out I changed the tie-rod ends on the steering rod also,only time it can be done anyways.I may not get her up and running today ..but tomorrow for sure.I am not rushing anything here...........
Will set up the primary also.Because these motors over-rev from the factory,I will be going 3.6 in both rivet holes.Have brand new stock weights and rollers going back in also.Cleaned and re-packed the drive shaft and jackshaft bearings with low temp grease at the same time and will still have to change chaincase oil.It is all coming together.Once I go thru the skid with either new or re-packed bearings..she'll be like brand new again..Actually wasn't that bad doing a rebuild,you learn a lot of new things.Now the next time I will hit 3000 miles on the motor..I will change the rings as alot of people say is what should be done.These motors are bulletproof.The motor had over 12,000 km's on it and the cross hatch on the cylinder walls were so present.These nikasil cylinders are tough.....
sleddineinar
She's lookin' good Doug! Keep up the good work.
thanks guys..nice project.I know it is alot of hard work,and some guys just try a re-build themselves..but this is my first time and it gets easier with time.Besides can't see paying the dealer $2000 to do it for me.
abumpa
Been following your progress. Nice job, well done! I will be bringing mine over when the time comes.
A couple of bucks
bluemonster1 said:I always use aluminum friendly anti-freeze and deionized water along with Water Wetter with my mixes.
Tell me some more about this WATER WETTER. Heard of it but that's about it.
when I find the bottle ,I'll shoot some info back.It is supposed to help in the cooling ..aids in some way,can't remember off the top of my head.
SX600abuser
Water Wetter-- http://www.redlineoil.com/Products.aspx?pcid=10
some info
Water wetter
Water Wetter®
Unique agent for cooling systems that doubles the wetting ability of water
Rust and corrosion protection allows for use of straight water in racing or reduced antifreeze levels in warm climates
Improves heat transfer and reduces cylinder head temperature
May allow more spark advance for increase power and efficiency
Use one bottle for most passenger cars and light trucks, treats 3 to 5 gallons or 13.2 to 15.9 liters. Vehicles with larger cooling systems should use two bottles. Small cooling systems should use 1oz (3 to 4 capfuls) per quart
Compatible with new or used antifreeze (including DEX-COOLTM and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems
Satisfies ASTM D2570 and ASTM D1384 corrosion tests for glycol-based antifreezes
WaterWetter - 12oz - $9.95
Quantity
ABOUT RED LINE WATER WETTER® COOLANT ADDITIVES
Reduces or eliminates bubbles or vapor barrier that form on hot metal surfaces to reduce coolant temperatures by up to 20°
Superior heat transfer properties compared to glycol-based antifreeze
Compatible with new or used antifreeze (including DEX-COOL and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems
Designed for use with all modern aluminum, cast iron, copper, brass and bronze cooling systems
Cleans and lubricates water pump seals
Reduces cavitation and complexes with hard water to reduce scaling
Does not lower cooling system below the thermostatically-controlled temperature
ALSO AVAILABLE FROM OUR DEALERS
80204
Water wetter
Water Wetter®
Quantity
80204
A couple of bucks
Anybody have a testimonial. So were probably adding @ 4 oz for our systems?
kzyodie
Great job Doug, I bought a 02 600sxr last fall and I,m going through it, suspension wheels, bearings seals completly tore rail apart! I got the machine for $460.00. Took it home and fired it right up!
these 600's are extremly bulletproof.I am not easy on mine,always have it pinned.But will be going crazy because can't do that for a couple of tanks until it is broken in properly..then look out.I love jumping anything at high speed,nothin like being air borne for a while..lolll
Hopefully I can get her running today.Just have airbos,exhaust and anti-freeze to mix yet..oh yeah and change chaincase oil.Probably will make a video of the start up again..got to love all that smoke...
