Another pain in the AZZ clutch question
00sxrjoe
Maine
I have checked the treads to find out info on 8cr setups but come up empty.
I have sx 700 with hauck pipes trying to set clutch up. It pulls like hell from a stop and slight roll, but when it just above a roll it hoggs up when i land on it. Back off the throttle you can here the clutch pop out it hit it again and HANG ON! I took out sum tip weight and it got better. Here is what I got. Shoot me some in put. Thanks
Engages at 4500-4700 rpm
8CR w/14.5 rollers
4.5 heel 2.7 tip
y-w-y spring
48/40
red spring at 80
22/39 gearing
cajones2 said:
What is your top end (GPS) with that setup?
I don't know. I have been testing on grass and do not have a gps. I just know it pulls hard. And will not back shift till i back off.
I found my prob i had a bad groove in one weight. Witch was causing it to hang. I reground them and it seam to fix my prob. Hope it did not make them to soft. At wot it will turn 9000rpm. That should be ok for pipes.That was on grass at a short dis.
Depending on what pipes you are running 9k is too high. Looking at a power curve there is a steep drop off after specified peak RPM, so you are actually going to drop Hp.
Gonna take it out and do some grass drags this week end. On an old air strip. Hope the guy that has the radar comes. Will have to see how well it goes.
