dsc577
i used LB05EZ got em from dennis kirk, 2.60 a piece,
L-is the shape
B-plug size,14mm
05-5 K ohm
E-terminal nut
Z-recreational/anti-vibrational
the center pin is a screw,just twist em off,end of my wires were green from corrosion,these caps have a longer neck allowing you to cut the wire back and they also have seperate boots on em which fit very tight
L-is the shape
B-plug size,14mm
05-5 K ohm
E-terminal nut
