my stator went out from water ridin and i bought a new one but it still dosent have spark help
Water reaks havok on any electrical system and if it shorted bad enough to damage a stator you probably have other issues as well. I would check all your wiring for shorts, if it all checks OK you could have a CDI issue. There are usually used CDIs available on EBay.
Bob
Bob
Are SXR's very good at water skipping?
If you are a good swimmer, why don't you go give it a try!
its good until it sinks..lolll.Why would you skip water with an SRX yet...was doing it with my 600 one year and the belt got wet and I almost didn't make it out....
nytrodave
SPI makes an aftermarket CDI for the red heads for $150. Yamaha is $500.
It is plug and play. It will also work on the older single headlight 700's, but the engine temp light will not work.
A couple of bucks
Water skipping results......
http://www.youtube.com/watch?v=UkC9JWfoAhA&playnext=1&list=PLFE9A12728667C4A4&index=35
Never let your LARGER/HEAVIER/INEXPERIENCED brother take your brand new sled out.
Couple of stupid twats!!!!! Where are their helmets? And if you going to play on open water like that, you better have a rescue line with you! The idiot walking out on the thin ice could have easily fallen through! Sht happens... be prepared for it
A couple of bucks said:Water skipping results......
That Video is just WAY TO SCARY!!! In so many ways!
A couple of bucks
Could have very well lost all of them.
pretty scary for that kid, you could see the fear on his face, the sled at that point was last on the list.
that happened to me when I was a kid, my dad told me to stay off the pond, there wasnt enough ice yet...............you know where I went,because it was fun to spin around doing brodies,well, I fell thru also, thankfully it was only in about 4 ft of water,but I still got grounded for a month off the sled right dead in the middle of a big snowy winter....lol
never been much for water crossin since then, this video reminds me all to well.........
A couple of bucks
Obviously, we all have our sled preference. But......that sure was a nice lookin DOO .
sxr still no sparkk
i did i got a used stator but it still has no spark then i got a used cdi box and it still has no sparkk, ,, will it matter if i am using a 600 triple stator because it still dosent work can somebody gimmie the low down on electrical 101!!!!
