need to adj the idle screws so that both slides are down equal and resting on them with 1/8 gap at lever,when you push the throttle and it pivots then moves both slides need to begin to move at the same time,ive heard of people putting drill bits under the slides and watching which one moves first,adj the cables under the rubber boot on top of the carbs till there the same,warm sled up and check idle speed,if you have to adj it higher youre putting more slack in the cables and need to check,adj again.make sure you keep gap at throttle lever or it will race engine when you turn,also will activate tors if you still have it,manometer is for rack style carbs with one cable,you got one into two system,sync carbs is a mechanical adj of slides and needle,the needle goes down threw the main jet and is tapered,when it is moving up out of jet it begins to let gas threw being metered by the taper until it is all the way out,the slides obviously let air in,the little screws on the side compensate for sudden opening of the throttle and are for fine tuning depending on weather changes,turn em allthe way in and back em out 3/4 to 7/8 for now.
