Ordered
With any lick I might be on the snow on Sunday
Don't take offense but it sounds like everything was fine just worn drivers.You said the studfs where too long?What size where they?You can run way longer studs in the srx the a 1"
Yes
The drivers were just so worn that track would be on top by the fourth tooth
So there is no way possible that the previous owner drove it that way
The studs were around 1.175 or longer
I put 1" in now, but I could have went longer
oh well
oh well
SHAMARKEN
Hey Kevin if you need stock drivers got some here!! you would need to get them pressed on...
Thanks for the offer
I bought 8 tooth ones today
I will press them on at home when I get them
Thanks again for the offer
Much appreciated!!
Much appreciated!!
SHAMARKEN
if you need a 37 tooth gear have an extra aswell for running an 8 tooth driver
Oh really
I forget what gears I have now.
So that gear will put it back to original gearing
Your original should be 37 tooth if it is still stock.
It get better
Took the primary off to test the new puller and it is full of cracks
Now looking for new clutch
Just wonder what will be next
Question
The bearings in the chain case
Does the open side of the bearing not face to the inside?
no it does not. reason is to keep shavings out of bearing.
to the inside of the chaincase? yes it should.KEVIN said:Question
how does it get lubed then?Maim said:no it does not. reason is to keep shavings out of bearing.
bluewho
Oil makes its way between the shaft and bearing thats why there is 2 seals there behind.
Ok so which way
Open side in or out
Open side in or out
bluebandit98
open inside
The driveshaft bearing located in the chaincase is installed so that the seal is TOWARDS the oil. This keeps the fine metal particles out of the bearing and enough oil weeps past the seal to keep it lubed. The lip located in the chaincase about an inch behind the bearing (looking from the chaincase side) keeps the crap out of the other side of the bearing.
Thanks for all the answers
So why not put a bearing in that is sealed on both sides
sgauthier
KEVIN, if you still need used parts give these guys a call. good people to deal with.
Total Recreation, tel 1-866-680-8316 or 705-327-0796. i believe they are located near Barrie or Parry Sound.good luck
