my SX600R clutching still a mystery to me..lol
Well since I rebuilt the motor,the 600 seems to have more power and it is showing up with higher rpms.Stock weights have from factory 2.4 in and 3.6 out.This creats over rev.I tried the other day 3.6 in and 4.5 out with red spring at 80.I am geared down 1 tooth upper with 1.25 track.Still revs up to 8800-8900 when I pin it ,settles down to 8500 and pu to about 8700 wot.So 1 gram extra on tip would drop it 100 rpm and if I go to red at 70 .should drop me another 200...but will this do it.Probably will still over rev out of the hole.Need the rpm's to settle down to 8200 and pu to 8400-8500 rpm.Will adding more to inner hole help here.I was going to add a .9g washer to the 4.5 rivet now and get it to a 5.4 g total outer...what do you think will happen now???Can I go to green spring at 60 wrap also...thanks
