my total volts were 5.05..times that by .136=.74. I adjusted to .74 and then at wot got 3.24..off a lot I think..you to.
bluemonster1 said:New TPS is installed.Following the manual I got 5.05 volts.Times that by .136 gives me voltage B which is .686 v.So I set the idle right..warmed up motor for a while and got idle where I want it and then adjusted TPS at idle to .68 v. At wide open throttle I get 3.11 volts.With the old one I couldn't set the idle volts lower then .79v...so something is a little different.This TPS is the updated part also ending in 02.I will take her out tomorrow and try again and see if there is a difference in performance.We 'll see if I blew $100 or not...![]()
