03viperguy
the sled is basically stock, only mod is the bored silencer. eems to use a good bit of oil (about twice what the viper uses, but unsure of exact amount) and I was wondering where the needles in the carbs and the oil pump setting should be. pulled the needles today and they are secon notch from the top. I know the stock setting is #3. so am I at #2? had 2 shims under it as well. I now have it set with 1 shim under, 1 over the clip. plugs (before this change) were wet and oily. thoughts or ramblings?? thanks in advance guys!!
03viperguy
anyone?
Oil pump bad or going bad...? Cable to tight...?
Nick
Nick
03viperguy
starting to think the cable needs to be loosened up a tad. moved to the tech section, hoping for more answers
03 i'm surprised you didn't search this all that info is here pal.03viperguy said:anyone?
03viperguy
I did search, really mostly interested in the needle position. I know what stock is, just not sure about the shims and if I am at position #2 or 4. how are they counted? and how much of a difference do the shims make? just seems like even with the rich oil pump, shouldnt it be a bit more lean with that clip position?? almopst all the info I found was for people with a 700, wasnt sure if the 6 was different
03viperguy
wel I finally remembered to check the throttle gap and it was nowhere near 2mm. more like 15. adjusted that, double checked the oil pump (set at 22mm now) and it seems a LOT better. not sure what difference the 1 shim made. do tose shims make that much difference?
