Tjc702
How much oil do you burn per tank of gas? I am going through a quart. Is this normal?
			A couple of bucks
							Tjc702
Nice link. Thanks.
			rx1jim
I believe the ideal ration for Yamaha two stroke engines is the consumption of 50 parts gas to 1 part oil.  I like to run my engine closer to 45 to 1, the idea being slightly more oil is better than less.  It sounds like you are running at a ratio of about 40 to 1 so you could adjust the oil cable to deliver slightly less oil.  If you do make an adjustment, make small adjustments and watch the oil consumption carefully.
			A couple of bucks
rx1jim said:I believe the ideal ration for Yamaha two stroke engines is the consumption of 50 parts gas to 1 part oil. I like to run my engine closer to 45 to 1, the idea being slightly more oil is better than less. It sounds like you are running at a ratio of about 40 to 1 so you could adjust the oil cable to deliver slightly less oil. If you do make an adjustment, make small adjustments and watch the oil consumption carefully.
Agree w/ Jim....Especially on.......'the idea being slightly more oil is better than less'.....especially on the PTO SIDE. My cable had to go all the way out to 23.5mm to achieve a ratio of about 48 to 1. Took alot of time and exact measuring for me to come to that approximate measurement. Running thin full syn though.
pman44
Tjc702-I have a 97 600 XTC and burn about a quart per tank.
			brad14880
im burning about a whole tank of oil to gas, is this bad?
			sleddineinar
brad14880 said:im burning about a whole tank of oil to gas, is this bad?
It's certainly not right...
brad14880
what do i have todo to check it out the lines on the pump and the cable line up, and the cable screw adjustment is almost down all the way
			Devilin AblueDress!
To brad, from what I have ben lead to beleive when pump fails it delivers oil as if  WOT all the time. I would suspect that is your problem,as well as could play into the bogging issues mentioned in other thread
			brad14880
its some thing clutching tho, the plugs look fine, and i have cleaned the carbs..
			brad14880
that bog i think is most definately clutching..
			Devilin AblueDress!
Thats why I said "playin into" if your already having a clutching issue, sounds as though its not back shifting, and engine is getting somewhere between 2 to 4 times as much oil as it should it is goin to compound problem. Does it seem to smoke more than usual or compared to other similar sleds
			horkn
Tjc702 said:How much oil do you burn per tank of gas? I am going through a quart. Is this normal?
Yes, that is normal. You will easily notice when the oil pump goes bad as it delivers full WOT oil even at idle.
horkn
You oil pump has failed in WOT position. it's very common on the 97 600 (and 500) twins. When I got my 97600 twin venture, it used about a tank of oil to a tank of gas as well. The original oil pump on these sleds in 97 were of poor quality. There was a service bulletin on them, but no recall. Look on port yamaha's website and find the oil pump on the micro fiche. That will show the updated part number. They are about 90 new, but you can get a used one that is not the original 97 part number and it will work fine. The oil pump on my venture is the first oil pump I've ever seen or heard of that has failed in all my years of snowmobiling (and oil injected 2 stroke outboard days too).
A new updated oil pump will fix that, and wake it up as well.
brad14880
the thing smokes like a bastard, it had power and such, but not as much as you would seem to think it would have
			Trail Ryder
 - Jan 4, 2006
horkn said:You oil pump has failed in WOT position. it's very common on the 97 600 (and 500) twins. When I got my 97600 twin venture, it used about a tank of oil to a tank of gas as well. The original oil pump on these sleds in 97 were of poor quality. There was a service bulletin on them, but no recall. Look on port yamaha's website and find the oil pump on the micro fiche. That will show the updated part number. They are about 90 new, but you can get a used one that is not the original 97 part number and it will work fine. The oil pump on my venture is the first oil pump I've ever seen or heard of that has failed in all my years of snowmobiling (and oil injected 2 stroke outboard days too).
Was the oil pump fixed for the 1998 VMax?
SRX500kid
i am not shore how much oil i burn per a tank but i bet it is a quart to a quart and a half! i probably get just 2 tanks of gas before i run out! is normal for a 2000 sx500r? it runes like a champ though!!!!!! please respond!!!!
			SRX500kid said:i am not shore how much oil i burn per a tank but i bet it is a quart to a quart and a half! i probably get just 2 tanks of gas before i run out! is normal for a 2000 sx500r? it runes like a champ though!!!!!! please respond!!!!
A 2001 SX500R holds 12 gallons of gas, so if you go through 2 tanks, that's 24 gallons of gas burned. 1 gallon = 4 quarts, so that means you have burned 96 quarts of gas. If you burn 1 quart of oil per 1 tank of gas as you stated, that means you have burned 2 quarts of oil and 96 quarts of fuel. 96 / 2 = a 48:1 ratio, no problem there.
SRX500kid
cool thank you!!!!!!LaPorte429 said:A 2001 SX500R holds 12 gallons of gas, so if you go through 2 tanks, that's 24 gallons of gas burned. 1 gallon = 4 quarts, so that means you have burned 96 quarts of gas. If you burn 1 quart of oil per 1 tank of gas as you stated, that means you have burned 2 quarts of oil and 96 quarts of fuel. 96 / 2 = a 48:1 ratio, no problem there.
