stripped the shaft again!!!
cougar1985
sault ste marie ontario
1994 vmax 600 with reverse,replaced the secondary shaft last year with a new unit,because i stripped the shaft where it goes into the other at the reverse setup.well quess what ?it did it again today,arggggh!is there a fix for this poor setup or am i doomed?i got pulled in by a polaris today and needless to say right now im not a very happy camper.
I had forgotten about that, you are talking about the collar that slips over the jackshaft and a stub shaft that goes into the chaincase I'll bet. You could either replace the shaft with a solid one, get the one you have now welded, in any case it is going to require removal. Might be able to get one at a salvage yard. I had a 94 and a 95, and I think the 95 was a one piece. You might be able to find a used one piece at one of the salvage yards.
yup thats the shaft alright.if you go with the one piece one will you lose reverse?the 94 has the optional reverse kit.
