mopar1rules
well guys, after hearing about all the people loosing rod bearings within the last 3 yrs on their vipers and srxs, and including myself this year, i was determined to find out why the vipers and srxs are affected, but not the red head sx-r's. well, i bought a sx-r 700 crankcase, and started comparing it to my viper/srx crankcase. right off the bat i thought it might be something w/that oil line that goes to the bottom of the lower case, for the pto cyl, cause its never a pto cylinder that goes down, its a center or mag. well, it can't be that, cause both the srx/viper and sx-r crankcases are the same in that respect. now, what's really different between the 2 cases and what i truely believe is the reason that vipers/srx lose rod bearings and sx-r's don't, is that the sx-r case has a "open" design, in the area after reed cage area and under the piston. now, on the viper/srx case, its got that radiused shaped casting/webbing, under the piston at bdc and the rod has to stick thru that like 19mm gap. know what i'm talking about?? i feel that its too hard for the oil/fuel mixture to get down to the rods, expecially when the engine is running at 9000+. what little bit of oil that goes down to the rod bearing, gets washed away from the poor ethanol fuel now a days. not to mention that there is "ramp like" protrusions of casting, that direct the oil/fuel mixture up to the bottom of the transfer runners, where it doesn't even hit the rod bearing. with the large "open" design like the sx-r's, the oil/fuel mixture gets down on that rod very easily, as the mixture doesn't need to go thru a 19mm or so slot. follow me?? i never really hear of a rod bearing going out, on engines w/"open" case style designs. i have a pic to post, to show the differences to those confused. also, i noticed that the oiling holes for the main bearings in the case, are .017" larger on the sx-r than on the srx/viper case. not to mention, that the oil grooves in the case, that's fed from the oil hole, are deeper in the sx-r case, than on the viper/srx case. so, i'm machining my bros viper case to be similar to a sx-r case and i'm drilling out and funneling the oil holes in the case. of course those holes have nothing to do w/the rod bearings, but why not lube the main bearings a little more?
i forgot to mention that i modded my bro's viper case this weekend and we'll see if the rods live longer now. i'll keep ya guys posted.
here is a pic, to show you the sx/sx-r case to the srx/viper case
