mrviper700 said:snip. Cars can spark knock and it wont do damage to soft cast pistons, because its all in differnt forms/stages, you may want to google up detonation and read about it to get a good understanding.
snip more good info
It's also my understanding that the differences in the flow of the exhaust plays a major roll in a 2 stroke's suseptability to damage from detonation.
Being the exhaust flows past the edge of the piston on a 2 stroke rather than flowing out through the port of the cylinder head (above and away from the piston), heat management is more efficient on a 4 stroke. In other words, the piston runs cooler on a 4 stroke and is less likely to build heat, that heat is passed through a much larger heat sink were as the piston in a 2 stroke only has the wrist pin, rod and to a lesser degree the cylinder wall.
O/T - Reading the crankshaft bearings is common practice when determining performance of compressed air induction engines. You can learn a lot about what's going on in the combustion chamber from the lower end as well as the valves/valve seats/pistons/rings/wrist pin.
Anyhow, thats what I've read and learned from looking over the shoulders of 4 stroke engine builders but my actual experience is limited. I was too busy putting it back together for the next round.
snomofo said:mrviper700 said:snip. Cars can spark knock and it wont do damage to soft cast pistons, because its all in differnt forms/stages, you may want to google up detonation and read about it to get a good understanding.
snip more good info
a 4-stroke also has more time between "power" strokes to cool down. i believe the egt temps of a well tuned 4-stroke are 200-300 deg ferenheit hotter??
ottawaair said:So what are the benefits of the extra material in the srx/viper cases. If it has nothing to do with oiling or performance, why did yamaha design the cases differently?
Yamablue said:Probably to limit the windage effect of the counter weights, and limit the dead space in the crankcase to keep the mixture moving and emusified at all times.
mopar1rules said:i'm machining my bros viper case to be similar to a sx-r case and i'm drilling out and funneling the oil holes in the case. of course those holes have nothing to do w/the rod bearings, but why not lube the main bearings a little more?
i forgot to mention that i modded my bro's viper case this weekend and we'll see if the rods live longer now. i'll keep ya guys posted.
here is a pic, to show you the sx/sx-r case to the srx/viper case
mopar1rules said:I'm pretty sure I'm onto something here. I knew it wasn't improper storage, detonation, or hotter timing like a few other members stated. I knew it was something else and I was determined to find out what.
mrviper700 said:
YA, AND THEIR GUYS HERE WITH SRX,S THAT HAVE NEVER HAD HEADS OFF WITH HIGH MILEAGE. LUCK OF THE DRAW I GUESS. 3:16 (yammie tony)03viperguy said:I had good oil. I lost the crank.
sideshowBob said:How did this all turn out?
Its interesting that some of the most successful stock and mod engines never had the webbing above the crankshaft.
ex: VMAX4, Mach Z tripple, 800 XCR, and the current Arctic Cat 800s...things that make you go Hmmmm..
