madzx2 said:
my exhaust port is 29.5mm from the top of the cylinder.
That (engine)will definitely make power at 8800rpm and then some over rev with that exh port, but your stock pipes wont do much good over 8600/8650, so you have a mismatch there in my opinion. That exh port would be like a aggressive lake race type port job, but should also have alot of compression to go along with the port. I dont personally see how you could make any good power at all at 9200rpm with stock pipes and the cdi, would be so far retarded it would be a real slug, youd have no heat at all in the pistons at that kind of rpm(rich running).
I also would suspect its a lower type compression engine thats why it wants to peak alot higher rpm then 8500rpm. More compression makes more low/midrange power with a LOWER peak rpm. the exact opposite with lower compression.
Looking at the dyno sheets, I see it kinda bouncing all over the place dropping a few then picking up a couple more within 150 some rpm in places, thats kinda bogus, and I suspect its likely dyno error.
shortening the pipes, yes, you can gain a slight bit of rpm, you will stretch out the pipes power range but youll also need to add timing to get power from over rev. The timing is fine up top for the over rev as its needed because the cdi box retrds the timing but may cause you problems down lower for a trail engine, this is NOT something I would do for a trail engine. ((Added ign. timing puts heat in the pistons, retarded timing puts heat in the pipes.))
a 150-155hp is easily doable on a trail port srx engine with pumpgas but the porting,compression,piston mod and headwork must all walk hand in hand. The head work is critical!! just a flat cut of the heads is not going to do it, they will need rechambered set up with the angles and the correct radius.
