s10mike
agreed, very good tuning tool.
madzx2
here's the tq and hp numbers
HP TQ BSFC
7400 114 80.8 0.66
7500 119.3 83.7 0.63
7600 121.4 83.8 0.63
7700 123.2 84 0.63
7800 131.3 88.4 0.6
7900 134.2 89.1 0.62
8000 139.7 91.8 0.59
8100 141.3 91.7 0.58
8200 144.3 92.5 0.57
8300 145.7 92.1 0.56
8400 144.7 90.3 0.56
8500 148.3 91.9 0.56
8600 145.8 88.9 0.58
8700 151 90.8 0.56
8800 151.2 90.3 0.56
8900 147.9 87.5 0.57
9000 146 85.4 0.59
added bsfc readings. this teast was done with the airbox on, air temp was 56.6 F, EGT@ WFO were 1325,1325,1308. main jets were 141.3
HP TQ BSFC
7400 114 80.8 0.66
7700 123.2 84 0.63
7800 131.3 88.4 0.6
8700 151 90.8 0.56
9000 146 85.4 0.59
When I guessed 147hp it was for 8500rpm...seems I almost nailed it!
Thanks for posting all of the numbers...I am suprised the sled made more power above 8600 after it dropped off???!!!
Bob
Bob
Corey9965
Yup I was thinking the same thing, Bob. It drops 3 horse then picks up 6 100 rpm later. So do you clutch it to hit 8500 pulling to 8700?
madzx2
i had 9 pulls today, all of them no matter what jetting was made peak at 8800 rpms. we tested airbox vs no airbox also.
first run, no airbox 152.5's = 145.5hp@8700 90.3tq@8100
second run, no airbox M 150 C 150 P 151.3= 146.7hp@8800 91.9tq@8200
third run, no airbox M 147.5 C 147.5 P 148.8= 145.1hp@8800 86.8tq@8100
fourth run, airbox same jetting as above 144.8hp@8600 91.7tq@8100
fifth run, airbox M 143.8 C 143.8 P 146.3= 147.1hp@8800 93.2tq@8200
sixth run, airbox M 141.3 C 141.3 P 141.3= 151.2hp@8800 92.5tq@8300
bufalobob
stock pipes & stock ignition making peak h.p. @ 8800 rpm? not likely.
based on the erratic h.p. @ peak rpm's i'd say the dyno brake was slipping.
bob
bob
madzx2
i am going to try running it at 8800 this winter just to see.
madzx2
Stick with around the stock 8500rpm and use that torque,,,,,,
madzx2
from what i gathered from talking to mark is that it should run at 8800? either way ive got some testing to do. this sickness never ends! ive never had anything dyno-ed before so if anyone could give me some feedback on my dyno sheets above that would be great.
sleddineinar
Interesting... I've never had anything dynoed either.
03viperguy
pretty cool. I hope to get my budget race sled dynoed as well this summer at some point. if I do I will post up as well
I was kinda hopin for a little higher number, but very cool, thanks for sharing.
madzx2
bufalobob said:stock pipes & stock ignition making peak h.p. @ 8800 rpm? not likely.
bob
i talked to mark about this and he told me, "The cylinder head modification is absolutely necessary for making power up top. The dip in the
curve is caused by the delta/angle of reproach vs. the piston and that needs to be correct for power up top." i will be having my heads cut to his suggestions and re dynoing it to see if it helps out. he also told me that my engine should be running 92-9400 rpms.
bufalobob
your rpm/h.p. #'s make no sense?? stock cdi & pipes fall off after 85-8600.
a good trail port job w/ mild comp. should make around 155 h.p. w/ a safe bsfc around 0.65 @ 85-8600.
bob
bob
madzx2
bufalobob said:your rpm/h.p. #'s make no sense?? stock cdi & pipes fall off after 85-8600.
bob
what doesnt make sense about them? im just trying to understand what you mean.
YAMMIEGOD3:16
DUDE I Made SLIGHTLY BETTER THAN YOU WITH THAT 2000 RACE BOX I GOT FROM YOU AND THIS SLED IS STILL LEGAL IN STOCK CLASSES ON GRASS AT C & H HERE IN NY. IF HE WANTS YOUR PEAK AT 9400, THATS WAY MORE THAN A fast TRAIL PORT JOB. MY SRX ACTED LIKE IT FELL OF A TABLE AT 8600. MY SWEET SPOT WAS 8100 TO 8500. HP AND TORQUE DID NOT DROP UNTIL I HIT 86. 3:16 (yammie tony)
madzx2 said:he also told me that my engine should be running 92-9400 rpms.
Not with stock pipes!
This is why it is so important that the porting specs have to match the pipes design so everything is in harmony at the proper RPM for max power.
JM.02c
Bob
madzx2
sideshowBob said:Not with stock pipes!
JM.02c
Bob
right i understand that part. he reccomended either shortening my pipes or finding a set that will run that high.
YAMMIEGOD3:16
GIAMETTI,s MOTORS THAT SPIN AT 9500 ARE RACE MOTORS. SOUNDS LIKE YOU ONLY HAVE THE APPETIZER THERE AND NOT THE FULL COURSE MEAL. THAT GUY BUILT SOME REAL NICE MOTORS. 3:16 (yammie tony)
