SRX500kid
my track on my sx500r has about two to three stud pull throwes and my dads articat
has about 15 to 20. should we replace the tracks????
How many lugs are ripped on your track?
SRX500kid
none really just stud pull throws
Your track is fine! Mine is just like that on my SRX- lugs are great but has a few picks that have pulled through- it's not like the track is going to fall apart. Sounds like your dad's track is throwing picks often, wouldn't want to shoot one through that heat exchanger!
super1c
Super Moderator
Yours should be ok for a bit. Your dads though sounds like its time. Once you start throwing that many studs the track is getting old and weak IMO. My viper threw a few last year so hoping to get through this year and replace next summer.
super1c said:Yours should be ok for a bit. Your dads though sounds like its time. Once you start throwing that many studs the track is getting old and weak IMO. My viper threw a few last year so hoping to get through this year and replace next summer.
Echo ^^^ there's no denying tracks are a wear item, it sucks that they are so expensive!
A couple of bucks
Let me guess.................there all on the outside. Or at least 9/10ths of em.
SRX500kid
i guess??A couple of bucks said:Let me guess.................there all on the outside. Or at least 9/10ths of em.
SRX500kid said:i guess??
Go check for us! This is generally the case, and why some choose to stud strictly down the middle, because the outsides get a lot more stress on them.
SRX500kid
SXR500 ALL ON OUTSIDE (ONLY 2 OR 3)
ARCTIC CAT 550 COUGAR DLX ALL OR MOST OUTSIDE STUDS ARE GONE
I DID NOT KNOW WHAT YOU GUYS WERE ASKING AT FIRST!
SRX500kid said:SXR500 ALL ON OUTSIDE (ONLY 2 OR 3)
ARCTIC CAT 550 COUGAR DLX ALL OR MOST OUTSIDE STUDS ARE GONE![]()
Oh okay, it happens! And your track is fine, your dad's I would not feel safe on!
SRX500kid
i know right!!!LaPorte429 said:Oh okay, it happens! And your track is fine, your dad's I would not feel safe on!
super1c
Super Moderator
SRX500kid,
Might want to take the rest out of yours on the outside. The holes left will be fine and then you dont have to worry about pull throughs with those. My 04 was studded on the outside when i got it and that was the first thing i did was pull those.
SRX500kid
i would not like to. maybe next season
super1c said:SRX500kid,
That might be a bit excessive with only a couple pulled through, my SRX 700 is the same: studded on the outside as well with a few picks pulled through. It's more of an issue with a higher hp sled. Still not a bad idea to preserve the track for years to come, unless he plans on replacing it in the near future.
Don't mean to hijack, but did you get the links to work in the technical pages super?
super1c
Super Moderator
SRX500kid said:i would not like to. maybe next season
Alrighty then. Laporte they work great, thanks again. Chris
super1c said:Alrighty then. Laporte they work great, thanks again. Chris
No problem I guarantee we aren't the only ones that have run across that problem!
SRX500kid
427cobra
Yeah I ran across the same question with the Yamaha I just rebuilt. The track had about 7 pull troughs. Most of were on the outside belts...
It comes down too what kind of luck you have. If your lucky you wont have any problems for many miles.
But as you know the pull troughs create a weak spot in the track.
I opted for a nice used track for the rebuild. Good luck with your sled!!
I would have to agree with the other posts. Your track is probably fine...your dads may need to be replaced...???
SRX500kid
THANK YOU GUYS BEEN A GREAT HELP GETTING PREPARED FOR THIS UP COMING SEASON... JUST THINK WE HAVE HUNTING SEASON AND THEN WE WILL BE ON OUR WAY!!! I LOVE THIS RIGHT KNOW! COOLER NIGHTS SHORTER DAYS... ONLY A MATTER OF TIME!!!!
CANT WAIT!!!!!!
sorry i am so happy but i am only 14!
CANT WAIT!!!!!!
