tyler440
Hey guys i have got a bit of an issue going on with my 93 VMAX 4. Last year i had my TORS kick in twice after being at WOT. I let off the the throttle slightly and then went to go again, TORS kicked in. it wouldn't go again until it idled down. Twice it did that, no more no less, with about 6-700 miles rode. Now granted that was probably at mile 500 that it did it. It was running fine when i drained the gas and parked it.
Now this year i put fresh gas in it and it acts like its not running on all cylinders. It is slow to rev even without a belt on it. Not really slow, but not the quick snap it should be, especially with no belt. In the higher rpms it seem to be more responsive.
also now probably 50% of the time when i run the rpms up to say 7k and let off the tors will kick in. ok fine, i say, i bypassed the tors correctly and it still lights the light and cuts spark. so i think "ok maybe in this model you leave it disconnected" so i did that. SAME EXACT outcome. it will rev up smoothly to at least 7k but not like it should. let off the gas and try to get back on it before it idles down and 50% of the time it will kick in tors.
I should also mention that with the poor throttle response, i already cleaned the carbs well. (didnt see more than just a light residue in them but i sprayed and blew and cleaned them anyways)
Spark seem good with an inline spark tester, on all 4 cylinders. From what i can feel with my bare hands it is firing on all 4.
with the tors system hooked up stock, totally disconnected, and connected to itself, it behaves the same. Is there anything else that could light the tors light? where are the grounds on this sled, i have only found the one on the radiator temp sensor.
PLEASE HELP GUYS, thanks
