sr522re
The following is listed in the tech pages as the optimal trail setup for my 2001 SX700R.
97-99 SX700 Trail
51/43 Helix, stock weights w4.5g rivet in 1st hole and 3.1g in tip. 2-3 engagement shims, stock springs, 1 or 2 layers removed from head gasket and 22/40 gearing. Jetting: 142.5 mains.
2000-01 SX700R
14.5 mm rollers in addition to above.
My question is, do I need to perform all of these changes at once to see improvement or can I do them individually and pick away at them over the winter while riding inbetween?
More specific as an example, will I see improvement if I only make changes to the primary clutch but don't change out my helix? Cost is an issue for me as I am trying to keep things cheap. A new 51/43 helix might be too expensive at this time or hard to find used but making the recommended changes to the primary are relatively inexpensive. Is it worth doing one but not the other?
And what about gearing? If I do the recommended primary clutch changes but don't change my gearing will I see any improvement or am I wasting time?
I am just looking for some input at this time. My sled is still in stock form but with most of these mods being cheap or free I figure I might as well try and get the most out of my sled. But if I have to spend hundreds of $$$ in order make it all work then I may just leave it stock for now.
Any and all input is most appreciated.
Thanks everyone in advance for your help! Let it snow!!!
97-99 SX700 Trail
2000-01 SX700R
