"srx whiteout project"
89 west of grand Marais = AMAZING! Nice long sweepers!
I just installed a sno tek sway bar on my srx this should help keep in planted in the turns.I will be using it this week and will see.
think your gonna need to flip that around, the links should be pointing up and the arms should be out somewhat level to the front. With them pointing down it cant apply twisiting load to the bar. I would think it will just limit the front suspension from ven moving and likely bend the tr. arm or the arm off the swaybar.
Yes I will have to try and flip it it does not bind right now all all I tried it with no shocks installed. I might be able to flip them up they r a bit long.
Well I put 700 miles on the srx and the new sway bar worked great no binding or damage.it is much stiffer now and corners like on rails.
Nice sled amatosrx. I love a white sled. I'm slowly turning mine white. Next summer I plan on powder costing everything white and getting a white seat cover.
WOW Pete !!!! When you asked if I had seen any of your builds I was thinking no big deal but again WOW !!!
Looks like your not a B S er and you do GOOD work !!!! I hadnt read these till today and Im impressed and wanted to
tell you THANKS AGAIN . Still planing a trip out west but if that falls apart maybe I can come up and ride with you for a weekend ?
THANKS AGAIN,
From a new FAN
