That squeeling is that for some reason the belt is too tight. Either center to center, wrong belt, or the shims on the 3 small adjusting bolts on the back of the sheave are to thick. Maybee just drop the belt down a little further into the sheave by removing the shims or thinner shims would be the easiest, but I would definitly do a clutch alignment to check. Also, their is no washer inside, just slip the secondary on then the washers. And last but not least, you must check the bearing behind the secondary every year before riding. Pull the secondary off and use a small pick to pull out the rubber seal on the bearing and you will see rust, then spray brakleen in it and compressed air until it is clean then regrease with lo temp snowmobile grease and replace the seal. Then repeat the process on the front shaft of the track behind the speedo drive. This will save a lot of time, money and embarrasment on the trail. You will also go faster, maybee.
