viperhauck
Yes but that is based on oem helix and I want to try run on the hauck v helixmodsrx said:if its a new kit u got a manual where to start with the bolts...hope the best for u ...i didnt get good result in trail with heel clicker in snow in warm days ...
Henrick, refer to helix specs in post #27, that helix you have is too steep in the finish angle to be able to use any weight in the H/C arms.
ADD: red primary spring, long bolt with 5 washers in heel.
long bolt 1 washer in center hole
tip empty
50/40 helix with green sec at 70-80
you want 9100rpm
tip empty
you want 9100rpm
viperhauck
Unwrapped the heelclicker box today and noticed the new nylon washers wasent there. instead it was metal washers in same thickness as the oem washers. In the manual it says nylon. Have they change anything in the kit? I measured the weights and they are as the oem weights in thickness so I toke the oem washers instead. Right or wrong?
you can use the stock,no issues
