Got her together this weekend and fired her up. Ran it through a couple heat cycles. Sounds good and seems to run good. The last run on the stand, I pinched it a couple times only for a second or 2. It appears to not be fully reving. Starting at around 6500rpm it starts to bog and fall on it's face. I think the most I seen was 7k. Again this was only for a second so it's hard to tell. We just got some snow lastnight so I will try and get it down to the lake and see what it does. Any idea's? It almost sounds to me like the spark is falling apart at high RPM's. I think I will put some new spark plug boots on just to rule it out.
